gun nuts i need help
BirchHatchery
i have a older 500 12 guage mossberg pump i have 2 barrels one barrel is a 2 3/4 26 inch Imp cylinder skeet, other is a 30 inch full choke both smooth barrels in the inside my question is can i shoot buckshot and slugs threw either of these barrels and if so wich barrel would be better for buckshot and slugs?
SKR8PN
Late For Supper
O-HI-UH
You can shoot buckshot thru either one of those barrels, but for accuracy with a slug, you will need a rifled slug barrel. Mossberg 500 slug barrels can be had pretty reasonably on Gunbroker.com
My current setup, is a 500 that I added a shortened(18.5 inches) slug barrel with rifle sights on it, and I shoot #4 or #00 buck with it. INCREDIBLE short range patterns with the rifled barrel makes it a GREAT "in house" gun.
ohiofarmgirl
Sipping Bacon Martinis
* snicker snicker snicker *
the first mention of "gun nuts" and SKR8PN is the first to arrive!
whoot! way to to, brother! *hugs SKR8PN*
Toulle
Don't run slugs through that full choke barrel. Full choke means there is a bit of taper, or the inside of the barrel actually narrows down a bit. You can see the problem pushing a solid slug through that. Buckshot will do fine in it, though. This is also a good barrel for shooting light shot like #6 or #8 like you would use for birds or squirrel.
The improved cylinder will work well with slugs. Buckshot will work too, but you will have a very wide pattern. This means the individual pellets will be scattered out over a wide area. You will hit more, but with less effect - one or two pellets per target rather than several.
BirchHatchery
so ur sayin if i wanted a more centered kill hit i should use the 30 inch full choke barrel for birdshot and buckshot this gun is more for home defense gun n some game kills
BirchHatchery
so wich barrel would be better for farther range kill with buckshot?
