You could line it with crushed limestone or marble for lighter stones to not absorb so much heat WZ. I think a small one would do just as well as a larger one, the only difference being the depth to keep it from evaporating so fast. If I were in your position I think I might try to make it more bowl shaped to add depth in the center of the pond, it would be a bit less surface area though, so not sure it would work as well.Wifezilla said:Water availability is a big issue here our west. I showed hubby the highlights of the information. He doesn't think it would work here. How small of a dew pond do you think I could make as a test? I have a little room in the front yard that I might be able to use as a testing area. It is a space I can't really grow much because of all the tree roots.
Do you think a modern version of shallow hole, straw lining, black pond liner and light colored rocks would work? The reason I say light colored rocks is they would not absorb loads of heat like dark rocks would.
Thoughts? Suggestions? Ideas?
